Re: has anyone every sand blasted a carb?
Posted by Andy Martin on November 30, 2004 at 11:35:11 from (64.219.39.195):
In Reply to: Re: has anyone every sand blasted a carb? posted by Theman on November 30, 2004 at 10:58:37:
The accelerator pump is effected by the stream of air bubbles in the main fuel tube with the holes on both sides. This air stream is introduced through the idle circuit air passages. The air bubbles through the perforated tube as the fuel is drawn into the engine. When the throttle plate is opened, the idle circuit is shut off. Since the throttle plate has opened, manifold vacuum is admitted to the venturi and the pressure around the fuel tube falls quickly. This causes the air bubbles in the fuel tube to explode and force the gasoline in the tube into the venturi and the engine. This extra fuel compensates for the engine's need for additional fuel to accelerate. I call this an accelerator pump because that is the function it performs. It was some pretty slick engineering in the '30's by IH engineers. No moving parts, but it is what makes an H or M respond to load changes like a hay baler stroking. Along with an excellent governer, the carburetor lets the tractor respond to every stroke of a baler. Carburetors with the air circuit plugged are very difficult to tune. One way to check is to adjust the idle mixture screw. On a lot of tractors the mixture screw seems to have no effect. This is because the screw adjusts idle circuit air, in for rich and out for lean, and if the circuit is plugged, the screw has no or nearly no affect on the engine. There is an arc segment on the engine side of the throttle shaft which serves as the idle circuit valve. It must be installed correctly and all the air passages clean in order for the carburetor to perform as designed. Although the IH carburetors have no mechanical accelerator pump, they do need the function and it is served by the air bleed into the main fuel stream.
Home
| Forums
Today's Featured Article -
Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
