Re: 1066 Hydro
Posted by Bernard le mécano on December 02, 2004 at 08:44:55 from (207.134.154.33):
In Reply to: 1066 Hydro posted by JLE on December 01, 2004 at 10:11:14:
Hi JLE, check if the hydro lever adjustemt is ok, may be the lever is worn and the reverser valve don't close enough, may be reverse relief valve is bad or the spring on the center section (neutral-valve) is broken or the snap-ring is pop out. You can plug the 2 small pipes on the left of the transmission housing. Be carefull when you make a test, the foot-inch pedal don't work, you stop the tractor with the lever only. Good luck!!
Bernard le mécano Québec Canada
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
