Re: white smoke and lots of it from my 560
Posted by captaink on December 02, 2004 at 12:43:54 from (66.115.214.56):
In Reply to: white smoke and lots of it from my 560 posted by Jim Ward on December 02, 2004 at 11:44:25:
As I posted last night, white smoke from a 560 is not uncommon upon start up and should clear in a couple minutes as the engine warms up. This is especially true if you don’t hold the glow plugs long enough, or your compression is low. Missing could be caused by a bad glow plug (so could the white smoke) and should go away after the engine runs for 5 to 7 minutes. Are you getting bubbles in the radiator or does the exhaust have a “sweet” smell to it like burning anti-freeze? If either is true then the head gasket is blown or you have a bad crack in the head or cylinder wall. If you are positive it is the head gasket it is not a terribly difficult job. To me the most frustrating part of doing a head gasket is the fuel tank. I usually try to burn off almost all the fuel then drain it and remove the tank and supporting bracket. I’ve also propped up the tank, but then it can get in your way. I’m thinking that you should be able to leave the manifolds on the head, but I would suggest taking a good look at the valves after you have the head off. They should almost be level with the deck of the head itself. If not, I would suggest taking it to a shop and having the seats replaced and the head brought back up to spec. You will be amazed at how much easier that old girl will start! Check the piston to cylinder clearance and ring grove to see how bad the bottom end is worn, at least then you will know what you have. My 2 cents…
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
