Re: Mounting IH 2350 loader on 966
Posted by Allan in NE on December 05, 2004 at 05:13:18 from (64.187.91.20):
In Reply to: Mounting IH 2350 loader on 966 posted by Iowa Farmer on December 04, 2004 at 20:15:57:
IF,
The loader mount, more than likely, is made to fit more than one application and hence the reason for your extra holes in the plate.
I'd bolt 'er on there using two grade 8 bolts per side. Sould work just fine.
Allan
Post a Followup
Subject:
