Mounting IH 2350 loader on 966
Posted by Iowa Farmer on December 04, 2004 at 20:15:57 from (167.142.12.63):
I am mounting a IH 2350 on my 966 and am having a little trouble figuring out how to mount the brackets. The front mounts-I have figured out, but the rear bracket is what I can figure out how to mount. The way I"m guessing it mounts, there arent enough holes in the frame. There are only 2 holes in the frame and the mount has 4. Do I need to drill 2 more holes ineach side or am I looking at this thing wrong. Any help is appriciated, I just dontwant to s[end the time drilling out my frame rails if I dont have to. ( The brackets came from an 856, possibly there may be a different set of brackets for a "66 series tractor, but I was told they would work form a couple of different sources. Sorry for the long post andI hope you can make heads or tails of it. Thanks!
Post a Followup
Subject:
