Re: Mounting IH 2350 loader on 966
Posted by K.B.-826 on December 05, 2004 at 16:27:23 from (209.163.30.76):
In Reply to: Mounting IH 2350 loader on 966 posted by Iowa Farmer on December 04, 2004 at 20:15:57:
You probably need to drill the holes, that's all, if you're lucky. 966 is a little wider than an 856, hopfully that won't cause you any trouble when you go to put the loader on. About two years ago, we bought a 2250 loader for our 706, not knowing what it had come off of. Ended up enlarging about six holes in each mount, and drilling two holes in each frame rail.
Post a Followup
Subject:
