Re: New Farmall can't get it started again, please
Posted by souNdguy on December 06, 2004 at 05:07:38 from (12.77.214.105):
In Reply to: New Farmall can't get it started again, please hel posted by Tanner Clark on December 06, 2004 at 04:47:51:
Pull a plug wire and see if you are getting spark when it is turning over.
If it is, next check to see if it is getting gas to the carb.
If it started and ran for 5 minutes and died, the float may be stuck, and either letting it flood out (stuck open), or letting the bowl go dry ( stuck closed - but letting some gas seep thru enough to get it started and run for 5 mins etc.. ).
All you need is air, fuel, spark, compression and near correct timing.
If it does spark.. try to see if it will start on a very small amount of ether.. or even wd-40 sprayed at the carb mouth.. if it starts fine on the wd-40 or ether.. might be a fuel delivery problem.. or woefully weak spark.
Soundguy
Post a Followup
Subject:
