Re: New Farmall can't get it started again, please
Posted by Frank DeWitt on December 06, 2004 at 08:22:44 from (66.82.9.62):
In Reply to: Re: New Farmall can't get it started again, please posted by Allan in NE on December 06, 2004 at 04:56:15:
It sounds like there are a lot of things just a little bit wrong (It started hard but did start before the trip tells me that) Getting an engine running and running right is just troubleshooting. one thing at a time until it runs. 4 requirements Fuel Compression Timing spark The good news is each one can be checked separately. It ran not long ago so it has fuel (but as others have said, it could be dirty or have a dirty filter. The 5 min run points to a dirty filter) I would use fresh gas and a new filter before going any further. Compression, It ran so it has it. might be low, That makes it hard to start but once you get it running you can check that. Timing you can put the tractor in high or use the crank to turn it over and watch the points open, look at the timing mark and see what the timing is. This will get you close, then once it is running you can tweek it. Spark. Others have told you how to check for it. Problems are wiring and cleanliness. The dist cap, inside of the dis, and the coil and wires need to be clean and dry. The low voltage side sounds suspect. I would disconnect all the wiring and hot wire it. Battery to ground good heavy clean connection Battery to starter same Battery to coil (disconnect the tractor wiring to the coil and replace it with a temporary one of your own. now you know you have volts to the coil. no wiring, no switches, no charger, nothing else to worry about until it is running right. (Remove this wire to stop engine) There should be a wire (low voltage, not spark plug) from the coil to the distributor. Leave that wire, or if it is messed up, replace it also there should be a condenser connected to the points. is that there? is it clean? As some one else said, you need a charger, A 10 amp will do. but you have to have one to trouble shoot and to bring the battery back up after the tractor has been sitting a long time. Frank
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
