Re: New Farmall can't get it started again, please
Posted by captaink on December 06, 2004 at 08:44:59 from (66.115.214.56):
In Reply to: New Farmall can't get it started again, please hel posted by Tanner Clark on December 06, 2004 at 04:47:51:
Just want to reiterate what others have said. Starters- 12 Volts will not ruin a 6-volt starter, but long cranking time (regardless of voltage) will. I’ve been staring my M on 12-volts with a 6-volt starter for over 20 years, 15 of them in the winter (including days at -20) on a daily basis. I never burned out a starter, but did have to replace starter drives. Second, check spark from the coil. Bright blue at least ½ inch from the high tension lead to a ground. If good there, pull a plug wire and make sure spark is good there. I would also recommend a complete set of new spark plugs as they may be fuel soaked and not sparking properly. Third, make sure it’s getting fuel and has compression. Try to start the tractor without choking. If it has fuel, and spark, it should start. As others have said, use starting fluid sparingly, if fuel is dripping from the bottom of the carburetor, it is probably flooded. Open the throttle half way or better and leave the choke off. You should get a pop or something. Post back and let us know how you are getting along.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
