Re: New Farmall can't get it started again, please
Posted by Harley on December 06, 2004 at 09:38:40 from (152.163.101.13):
In Reply to: New Farmall can't get it started again, please hel posted by Tanner Clark on December 06, 2004 at 04:47:51:
Just a quick fix to get the thing back of the garage for Christmas. We used to do this at home when we had to. Manually jack up the loader bucket a couple of inches or enough to get a chain under it, run the chain up to the frame rail, then pull back on the hydraulic lever like you were raising it if it was running while someone pulls you around. If you can get up enough speed in fifth, the loader will come up as the pump is turning, and wala the loader is off the ground. This will at least get it off the driveway and yard before you tear something up and the wifey takes your Christmas present back to the store. Later, Harley
Post a Followup
Subject:
