Re: WD-9 Fuel Filter
Posted by Bob on December 07, 2004 at 17:49:09 from (66.163.134.177):
In Reply to: WD-9 Fuel Filter posted by WD-9 on December 07, 2004 at 17:35:02:
For a WD-9, WIX shows #33147, 16 micron,
and ..................#33148, 10 micron
The Wix catalog lists the 33147 16 micron filter as the secondary filter, and the 33148 10 micron filter as the primary filter, but I wonder if they could have the numbers transposed?
The 33147 is 6.344" high, 3.278" O.D., with an I.D. of 1.031".
The 33148 is 6.681" high, 3.372 O.D., with an I.D. at the top of .553", and an I.D. at the bottom of 1.341".
Do you have your old filter to compare these dimensions to?
Post a Followup
Subject:
