Re: hydraulic question
Posted by the tractor vet on December 08, 2004 at 10:28:11 from (4.124.69.2):
In Reply to: hydraulic question posted by Chadd on December 08, 2004 at 09:40:05:
Ok , the 806 has probably a 1750 releif valve and the 966 is probably a 2150 or higher . And also when was the last time that the hdy.filter was changed ??? The best way to check the system out is to flowrate it and see if the pump is up to snuff and where the releif is popen. A new pump maybe in order. If the pump is in good shape then install a higher releif.
Post a Followup
Subject:
Today's Featured Article - A Tinker’s Guide to Manifold Repairs - by Curtis Von Fange. A common characteristic of keeping older equipment is that some parts to make repairs can be extremely difficult to locate. For example, finding a replacement for a cracked intake or exhaust manifold on a unique tractor or odd brand can be a frustrating and downright impossible mission. So, what is an alternative solution to scraping out that ‘one of a kind’ piece of history? First, decide if you are one to try a repair yourself or have someone else do it. If you are uncomfortable about ... [Read Article]
