Re: is this it?
Posted by Allan in NE on December 08, 2004 at 14:09:50 from (148.63.132.164):
In Reply to: Re: is this it? posted by bad mechanic on December 08, 2004 at 13:55:05:
It is harder to pull your socks on in the morning.
Pull your hydraulic pump off the tractor's PTO shaft, put the adaptor on in it's place. I like to put a 1/4" bolt thru the adaptor and the tractor's PTO shaft.
Then, just slide your hydraulic pump onto the extension and hook up your second implement back behind the pump. There should be a slot in the extension for your implement's PTO lock to slide into.
Allan
Post a Followup
Subject:
