Re: Carb problem
Posted by souNdguy on December 08, 2004 at 17:26:31 from (12.77.215.212):
In Reply to: Carb problem posted by Rick Rodgers on December 08, 2004 at 17:13:44:
I have a 66 cub I've been dinking with. I reccomed you get an I&T IH-8 manual.. it covers the cubs prior to 57. My cub is inthe IH-50 manual. If your governor is similar to mine, you will notice that is controlls engine rpm, based on the throttle setting. As you know.. your hand throttle is what tells the governor what the power demand is. once set, the governor will attempt to maintain engine rpm up to its capability.. thats why when you hit a heavier load.. like mowing and hititng thick grass.. the rpms drop a tad.. and then come back up as the governor compensates. If you need choke to run.. you may have any number of problems from blocked fuel delivery due to a non vented cap.. but that usually takes a few minutes to develop.. or could be trash in a screen, or the mainjet inthe carb.. or in the float needle. Could also be weak sparks needing an enriched mixture to fire better. Could also be a vacume leak leaning out the mix needing carb choke to enrich it back claose to normal. The 'propane' test will help find the vacume leak. Simply take a small plumbers propane torch and open the valve.. ( don't light it! ) and wave it around the carb and manifold. If you get a change in engine rpm when you do this.. you have found a leak, as the propane is getting sucked in and enriching the combustable mix. If you still have the oem IH carb, TSC carries the kit to rebuild it. if you have the newer zenith carb from the cub 184/185, I know you can get the kit at napa. See my above post for the number. ( If it isn't a vacume leak.. check those points and ignition switch! ) Good luck! Soundguy
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
