SMTA hydraulic problem
Posted by Alaskapete on December 08, 2004 at 18:35:36 from (69.174.231.19):
I am getting no flow through the hydraulic remote control valve. It seems as though the rod is not connected to the valve. I have opened the top of the valve box by removing three bolts and the square nut on the top of the box. My parts manual does not show the parts inside the box other than the centering spring assembly. How do all those parts work together to have the lever activate the valve? Thanks for your help.
Post a Followup
Subject:
