Re: Is this a B or an A?
Posted by gene b on December 09, 2004 at 12:12:41 from (66.43.221.243):
In Reply to: Is this a B or an A? posted by JBlavl on December 09, 2004 at 08:12:09:
This is a B with the axle extension on the left side removed and a drive axle installed from an A. Then you set the rear tread so the tractor will be stable enough for a WOODS belley mower and that way the left side runs inside of the mower swath. There are several ones around here and i have set some up that way. You just cut 22in out of the drawbar and weld together. Makes a great set-up. Wheel wts can be added inside of the center section for stability. Setting the rear tread is much easier with turf tires as you dont have to worry about tread going the rite way. Single fronts are easier to steer and are quicker for around trees ect. Another thing go to a muffler shop and have them bend a u-shaped piece so the muffler hangs down and dont catch on tree limbs.
Post a Followup
Subject:
