Re: Gov. Adjustment
Posted by REA on December 12, 2004 at 14:36:21 from (65.99.135.176):
In Reply to: Gov. Adjustment posted by T Quick on December 11, 2004 at 08:29:55:
Hi T Quick,
I did have the instructions to set the governor system up. From memory this may not be precise, but believe that you have to have the governor lever fully towards the carburetor (tractor not running)adjust the linkage place assembly back together. When I locate the instructions I'll give you a return message. May be someone else has a comment?
To be on the safe side make a mark on the leakage, so you can return to it if my memory is missing something. Hope this helps.
Bob
Post a Followup
Subject:
