Re: Farmall A cooling system
Posted by Dente on December 15, 2004 at 08:45:07 from (152.163.101.13):
In Reply to: Re: Farmall A cooling system posted by RayP(MI) on December 14, 2004 at 18:49:09:
Ray, Well when I filled the radiator I added the water followed by the antifreeze. Don't tell me I might have made a bad move doing that. What is the problem with that?
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
