Re: 1066 ???
Posted by dph on December 16, 2004 at 05:11:41 from (152.163.101.13):
In Reply to: 1066 ??? posted by PJB on December 16, 2004 at 05:00:59:
It's locked in two gears, probably low and reverse. Rev it up really high and... NO, just kidding. :) Don't do that. You should be able to pry the reverse linkage ahead at the shift console. If it is ahead, and the shift lever lines up with all sides in neautral, then the problem is lower. Keep following the linkages down. I don't think it is likely, but you might have to pull the tranny top. If so, not a bad job. Let us know how you turn out.
Post a Followup
Subject:
