Re: A turns over SLOW
Posted by Bob M on December 16, 2004 at 05:42:40 from (151.190.254.106):
In Reply to: A turns over SLOW posted by Shaggy on December 15, 2004 at 21:53:08:
Shaggy – Good advice below – especially regarding the cables. Make sure the cables are adequately sized (AWG #1 minimum), are as short as possible, and that the terminals are in good shape and soldered – not just crimped. (Often crimped terminals look good from the outside but are actually making contact on only a few strands of the cable inside.) Another item to check: The starter switch. As the switch is used it’s copper contact faces wear/burn away causing it’s resistance to increase. Try cranking the engine for 10 seconds or so then immediately feel around the switch. If it is any warmer than the surrounding components it should be replaced. Hugh’s advice to run the battery ground cable to a tranny cover bolt is good. I like to take it one step further: Attach the ground cable under one of the starter mounting bolts. With a good battery, cables and starter your SA should tip over smartly on 6 volts! ...Bob
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
