Re: clutch relese fork return spring pin on 45 H
Posted by Theman on December 16, 2004 at 09:37:31 from (65.248.77.5):
In Reply to: clutch relese fork return spring pin on 45 H posted by mike66 on December 15, 2004 at 07:55:31:
If you tinnk this pin will cause trouble later, now is the time to fix it. You should be able to remove it with a drift and hammer. If you can't find a replacement, weld the hole up and re-drill after letting it air cool. The liftall on my '47 H had a rubber seal in the casting for the control shaft. You have to take the pump out of the housing and loosen the clamp screw on the actuator bellcrank to remove the shaft. The counterbore for the seal will be evident when you remove the shaft. If CIH doesn't have the part, a bearing retailer can sell you a seal that will press into the housing. You have to give them the counterbore ID, shaft OD, and the depth of the counterbore.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
