Re: To much fuel now?
Posted by CNKS on December 18, 2004 at 13:42:00 from (204.249.178.138):
In Reply to: To much fuel now? posted by Shaggy on December 18, 2004 at 06:42:08:
Whatever works -- but those engines usually run rich, not lean. I think you had something plugged and compensated for it with a larger jet. It should only give an occasional puff of smoke under acceleration.
Post a Followup
Subject:
