Re: Diagnosing my electronics baby steps.
Posted by Magman on December 20, 2004 at 06:33:24 from (152.163.101.13):
In Reply to: Re: Diagnosing my electronics baby steps. posted by riverbend on December 20, 2004 at 05:14:16:
Hi Tanner, It sound like the dist shaft may be worn out all the little nubs should touch. This is what I do If i know there is no power going to the dist pull the coil wire then turn the motor over by the fan blade if the belts not tight you may have to push on the belt in the middle to tighten it then with the other hane turn the the fan blade. If you have a lot of compression then you may have to take the plugs out. Just make sure if you do this you take the coil wire of to make sure you dont get an accidental start and take your hand off. JON
Post a Followup
Subject:
