Re: Diagnosing my electronics baby steps.
Posted by riverbend on December 20, 2004 at 05:14:16 from (208.160.33.33):
In Reply to: Diagnosing my electronics baby steps. posted by Tanner Clark on December 20, 2004 at 04:17:21:
Right on both counts. When the points are closed, the voltage on the distributor side of the coil goes to zero. The cam in the distributor should open the points 4 times per revolution of the distributor shaft. When the points are closed, current flows through the coil and sets up a magnetic field. When the points open, the current flow stops, the magnetic field in the coil's primary winding collapses, and creates a high voltage in the seconary windings. That give you the spark. Your distributor bushings or shaft might be worn out, that could let the shaft wobble around. You can set the point gap on any of the lobes (corners) of the dist. cam. If you set the gap on the #4 firing position (opposite #1), will the points close on all the flats ? If so, you might be able to get it to run that way. If you have a belt pulley, you can use that to turn the engine over. With out a belt pulley or a crank, you can put the tractor in 5th gear and push on the rear wheel to turn the motor. In either case, it is easier with the plugs out. Tanner, I'm curious, how old are you and what was your first car ? Greg
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
