Running a 400 without power steering motor
Posted by HSE on April 04, 2009 at 06:02:39 from (70.104.106.54):
Bought a 400 farmall that somebody previously removed the Power Steering Unit (believe it was a behlen unit) in the steering shaft. My question is "What do I need to do to hydraulic system to run this tractor?"
Do I:
A: Loop hydraulic feed and return together?
B: Plug off both of them?
C: Remove a spring or priority valve or flow divider somewhere?
Not sure about A ..... will it cause other hydarulics not to work?
I figure B is wrong because flow will be deadheaded.
I have no idea about which internal valve to do what to on C.
I have a short piece of shaft already in place of where motor unit was. I also do plan on someday adding a power steering unit back in place. Serial number is #6556 if this makes a difference.
Thanks for any help!
