Re: Running a 400 without power steering motor
Posted by MIKE FRENCH on April 04, 2009 at 10:43:57 from (76.2.186.198):
In Reply to: Running a 400 without power steering motor posted by HSE on April 04, 2009 at 06:02:39:
You can just remove the hoses and cap the fittings, one on the priority valve and othe at the tank. Since there is no priority flow all will go throught the hydraulics with no problem. If wanted you can remove the complete priority valve and replace it with a non power steering one if wished, if the powersteering priority valve is good, it is worth a little money, good luck.
