Re: Q for Bob M or others - diode in 3-wire, start
Posted by Doug in OR on December 21, 2004 at 21:50:32 from (24.20.250.197):
In Reply to: Q for Bob M or others - diode in 3-wire, starter s posted by Dave in CT on December 21, 2004 at 20:15:11:
First of all, the wire from the number 2 terminal is a bit heavy. As Bob said, you can get by with lighter wire - probably down to 18 AWG. This wire is merely a voltage sense and carries no significant amperage to worry about. As for the diode - I think you are referring to a 1N400x diode. The 'x' is the PIV rating. A 1 means 100 volts... 2 means 200 volts... etc. The most common size you will find at Radio Shack is the 1N4003. This is plenty of diode. As for the lamp: This works and is a good idea. Short of installing a voltmeter, the lamp is the single best way to determine if your alternator is charging. In reality, if you use the proper size lamp you would not even need the diode. The lamp will drop enough voltage when you shut the tractor down and your back feed will not be enough to fire the coil. Remember that a silicone diode (don't even think of putting a germanium diode here) drops .6 volts in the forward bias mode. This may or may not affect where your alternator starts charging when you also have a lamp in series with it. As for the solenoid...... I wouldn't bother with it. Besides, 4/0 wire is plenty heavy. How do you even bend that stuff? You have more than enough of a hunk of cable between your battery and your starter - I wouldn't cobble it up with a solenoid.
Home
| Forums
Today's Featured Article -
The Tractor Parade: Story of a Case SC - by Bernie DeLon. On a early fall morning back in 1994, I opened the newspaper and happened to spy an article about a local antique tractor club having their annual show that weekend.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
