Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Super A Charging System
Posted by Curt Cooke on November 23, 1999 at 19:54:50 from (207.75.224.95):
In Reply to: Re: Re: Re: Re: Super A Charging System posted by Stan on November 23, 1999 at 17:44:14:
Stan, I have seen two types of adjusters on these things. One type is nice and simple with a phillips screw controlling the pull on a regular coil type spring. The other type takes a very small nut driver to loosten the top half of the contact so that you can push it down harder against the the other point and retighten. Do you have a parts book? I do, and if you email me, I can direct you by parts book pictures and numbers.
Curt
Post A Followup
: Re: Re: Re: Re: Re: Re: Super A Charging System
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
