Farmall Tractors Discussion Board |
Re: Re: Re: Re: Re: Re: Super A Charging System
Posted by Stan on November 24, 1999 at 18:10:41 from (12.67.148.110):
In Reply to: Re: Re: Re: Re: Re: Super A Charging System posted by Curt Cooke on November 23, 1999 at 19:54:50:
Curt Happy Thanksgiving and thanks again for the help. I had a chance today to take the tractor out for a while and pull a couple things around the yard and here's what happened. When I started the tractor I expected, from what went on the other night, that when I pulled the rod that she would turn over as quick as it did after I shut her down the other night, She didn't. Turned over like a dead battery. This tractor has always been a good starter and after several very slows turns she did start. The charge needle then went all the way as far to the charge side as it could. Now seeing the needle that far on the charge side I tried the lights and it stayed on the plus side with the lights on. After letting her run for about ten minutes I noticed the needle jumped around quite a bit but never went on the negative side. From your post: I do not have the Phillips screw type but I may have the other type you talked about. I will check this and let you know what happens. Go Lions !!!
Home
| Forums
Today's Featured Article -
Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
