Re: Q for Bob M or others - diode in 3-wire, start
Posted by Bob M on December 22, 2004 at 04:23:48 from (151.190.254.108):
In Reply to: Q for Bob M or others - diode in 3-wire, starter s posted by Dave in CT on December 21, 2004 at 20:15:11:
Dave - To your questions: 1 – As the others suggest below, for the #2 terminal wire you can use as small gage wire as is mechanically possible. (#2 is the voltage sense terminal for the internal regulator. It carries only a miniscule amount of current - something on the order of 1 milliampere.) 2 – Use either a warning light OR a diode, but not both! No need to worry about draining the battery when shut down thru the warning light – the system is specifically designed to work with the light. However if you are concerned about the warning light burning out and disabling the alternator while running, you can wire a 15 to 30 ohm, 2 watt (minimum) resistor in parallel with the lamp. 3 – You sure you’ve got 4/0 primary wire there and not AWG #4? 4/0 is HUGE - like ½” iron pipe. Anyway, with cable that heavy you certain won’t need to add a solenoid to reduce the cable length – the extra couple feet of cable is inconsequential! Hope this helps...
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
