Re: Need info on IH Power Unit
Posted by gene b on December 22, 2004 at 17:02:25 from (66.43.221.243):
In Reply to: Need info on IH Power Unit posted by Roger W on December 22, 2004 at 16:25:01:
Looks like a U-2. It will bolt up to an Aor B. But dont try and use the starter as it runs reverse direction from what you will need on a tractor. The BENDIX is even left-hand rotation. You can change the poles of the fields to reverse rotation but will need to change the BENDIX. Check the crankshaft to see if it is bored for a pilot bearing. Yours looks like it could be. Those engines without a clutch usually werent bored for a pilot bearing.
Post a Followup
Subject:
