Re: 1966 farmall 140 water leak
Posted by Hugh MacKay on December 23, 2004 at 02:51:43 from (216.208.58.133):
In Reply to: 1966 farmall 140 water leak posted by Huston Lloyd on December 22, 2004 at 20:56:45:
Huston: All I use is a bottle jack along with a pallet jack. I keep a number of good hardwood pallets, some 2, 4 and 6 inch blocking and ratchet tie down straps. In splitting my 130 at the clutch housing, here is my proceedure; Put wedges in oscillation point of front axle, choke rear wheels, place a pallet under front end of tractor. Block in from pallet to each side under axle and to oil pan just ahead of clutch housing. I build a cradle so sides of block take weight and not oil pan. I then use shim material so when I jack pallet all 3 stacks of blocks make contact at same time. raise pallet jack so blocking is tight. Apply ratchet straps from tractor to pallet at 3 points. Now the front of tractor and pallet are one piece. Just place the bottle jack under clutch housing to take weight. You are ready to unbolt and separate tractor. The beauty of this you can wheel the entire front end out of your way and use pallet jack for another move. I have split tractors as large as 560 with this. If you have enough pallets, blocking and tie down straps you can dismantle your entire tractor component by component. I have removed 20.8 x 38 tires and wheels, full of calcium chloride, in a standing position, using pallet, blocking and 4 tie down straps. I wouldn't be afraid to split a 150 hp tractor using this. As you know I have quite a few implements for my offset tractors. For winter storage I just set them on pallets, using the jack I can manuver them places I could think of with tractor. My advice is buy the pallet jack then the tractor. Wouldn't be without that pallet jack.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
