Re: 1966 farmall 140 water leak
Posted by lee on December 23, 2004 at 08:51:27 from (24.24.95.246):
In Reply to: 1966 farmall 140 water leak posted by Huston Lloyd on December 22, 2004 at 20:56:45:
I use a 10 x10 overhead bridge crane set-up. Run one chain fall off a bridge beam trolley to a point just ahead of the split point. The second chain fall off a seccond trolley on the bridge beam to a point behind the split point. Split the tractor and roll the sections apart.
Post a Followup
Subject:
