Re: 6 volts to 12
Posted by PAULIH300 on December 23, 2004 at 16:01:26 from (64.12.117.13):
In Reply to: Re: 6 volts to 12 posted by Doug in OR on December 23, 2004 at 15:27:42:
My Delco 1 wire excites with just a blip to 2000 rpm,and continues pumping out down to 500rpm.I run a master disconnect to shut off any drains.
Yes,1-wire alternators will drain in the milliamp range,it takes 1-2 months to really drain the battery though.
Post a Followup
Subject:
