Re: Bosch #'s for starter in above post...
Posted by El Toro on December 28, 2004 at 05:32:08 from (216.148.246.90):
In Reply to: Bosch #'s for starter in above post... posted by fixitforfree on December 27, 2004 at 20:12:22:
If the heavier battery cables doesn't solve the cranking problem find a shop that rebuilds starters, generators and altenators. Call around and find a shop that can load test that Bosch starter. It would help your starting by installing a block heater to preheat the engine
this would require less starting amperage. Try
Phillips & Temro at 1-800-328-6108 for a heater.
They can give you a distrbutor in your area. Hal
Post a Followup
Subject:
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
