Re: M drive shaft coupling question
Posted by captaink on December 29, 2004 at 07:24:20 from (66.115.214.56):
In Reply to: M drive shaft coupling question posted by Stroked550 on December 28, 2004 at 21:03:37:
Get the right parts. There should not be any play in there at all other than the give from the rubber washers. Otherwise the clutch shaft could move back and forth in the clutch disk and pilot bearing.
My 2 cents...
Post a Followup
Subject:
