Re: clutch stuck on a cub
Posted by Kevin (FL) on December 30, 2004 at 07:00:52 from (12.77.198.255):
In Reply to: clutch stuck on a cub posted by andruw50 on December 29, 2004 at 11:29:54:
Does the pedal go down but the pressure plate isn't releasing? If it's only been stuck for a short while, the disc might be just stuck to the flywheel or pressure plate with surface rust. If you're working alone, jackup one rear, shift into 1st, use a 2x4 or something to press the clutch all the way down and then turn the raised rear tire back and forth until the clutch lets go. If you have a helper with another tractor, you can pull the tractor with the clutch disengaged and tranny in gear. Be very careful as you know the front ends are very weak and the block casting is "soft"--easy to break the engine mount area. Use rope, not chain and pull gently or tow from rear instead of front. To assist with the job, you can spray some Gunk engine cleaner up into the bell housing, trying to get it to the top of the flywheel and run down onto the clutch/pressure plate and also the clutch fork area too. All this is said with the assumption that you have no mechanical issue with the clutch fork, throwout bearing etc and that the clutch is just stuck lightly from not using the tractor a few months.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
