SMTA steering shaft bearing ??
Posted by Todd L on December 30, 2004 at 13:21:27 from (12.36.202.50):
I have been off work since chrismas so I decided to spend my time working on my SMTA. I have got the motor somewhat tore down. I wanted to pull the radiator to have it cleaned out good. When I took the steering shaft apart to slide it out through the radiator hole the ball bearings inside the cap on the front came out in lots of peices. Where can I get this bearing? I also noticed that the clutch pedal has some slack in it. Side to side slack. Is there a bushing on the shaft that comes out of the side of the housing? I've ordered a manual but it hasn't arrived yet so thanks for any help.
Post a Followup
Subject:
