Re: SMTA steering shaft bearing ??
Posted by CNKS on December 30, 2004 at 19:20:17 from (204.249.178.138):
In Reply to: SMTA steering shaft bearing ?? posted by Todd L on December 30, 2004 at 13:21:27:
Your bearing questions have been answered as well as the clutch pedal, except that the shaft will also be worn. The same machine shop can build it up. Check the brake pedals on the other side. If the shaft is worn there, too, the shop may be able to make you a new shaft cheaper than the rebuild, as a shop did for the one on my Super H.
Post a Followup
Subject:
