Re: Farmall H Help!!!
Posted by arod on December 30, 2004 at 14:55:10 from (130.20.12.207):
In Reply to: Farmall H Help!!! posted by gadawg on December 30, 2004 at 14:40:52:
well let's see.
It ran when you got it, you did not do anything to compromise compression, i.e. remove rocker arms, etc. So it has good compression. You did not rebuild carb and fuel line was not plugged before. So you have fuel. Lastly however, you did remove the distributor to put a new gasket on it? Maybe you are 180 degrees off timing.
The tractor is tough to turn over when pulling on the flywheel and gas runs out when you unscrew the line at the carb input? Timing is off. Try again.
Post a Followup
Subject:
