Re: Farmall H Help!!!
Posted by captaink on December 30, 2004 at 16:02:46 from (64.33.250.37):
In Reply to: Farmall H Help!!! posted by gadawg on December 30, 2004 at 14:40:52:
Sounds to me like the wire that is powering the coil is getting power from the starter switch or solenoid instead of the switch. I’m not sure if you did a 12-volt conversion or not and if so have a resistor and if the wiring diagram was for a 12-volt start/6-volt run for voltage to the coil. Either way, make sure that the wire supplying power to the coil is hot when the switch is on.
Hope this is it!
Post a Followup
Subject:
