Re: Head over-torqued Farmall H
Posted by CNKS on December 31, 2004 at 07:24:35 from (204.249.178.138):
In Reply to: Head over-torqued Farmall H posted by John in Ne. on December 31, 2004 at 06:50:15:
On my Super H I got my finger caught between one of the studs and a bolt hole in the head, while installing it. After much panic, I got my finger out, leaving a chunk of meat. Before going to the ER, I bled all over the place and hurried to torque the bolts, since I had sealer on the gasket. Forgot the spec and torqued to 80 lbs. After running the tractor a while, the torque setting was still 80 lbs. Unless you mashed the gasket, I think you are ok, just like my finger.
Post a Followup
Subject:
