Re: painting question
Posted by boby man for twenty years on December 31, 2004 at 17:39:13 from (207.190.90.171):
In Reply to: painting question posted by Hman on December 31, 2004 at 12:21:19:
the enamel paint system is obsolete. I use only acrylic urethane on mytractors. It is a bit more expensive but it will never fade as long as you live, and has a lifetime warrenty. I use ppg only products and all colors are available for international tractors. Also a note paint will not dry below 70 degrees, 16 hours at 70 degrees to touch 72 hours for full cure,unless you bake it with a infrared light. hope this helps.
Post a Followup
Subject:
