Re: Farmall 300 Govenor
Posted by PAULIH300 on January 01, 2005 at 16:06:44 from (152.163.101.13):
In Reply to: Farmall 300 Govenor posted by Hogman on January 01, 2005 at 15:41:09:
You must have play in the linkage between the hand lever and the governor itself.Watch the rod that runs behind the carb carefully as you slowly move the throttle....bet there is a lot of slop there.The play is usually (in my case anyway) in the rods and bellcranks behind the dash,and the setscrew that holds the hand lever from spinning on its shaft.
Post a Followup
Subject:
