Re: water leak, frost plug?
Posted by captaink on January 03, 2005 at 08:26:10 from (66.115.214.56):
In Reply to: water leak, frost plug? posted by cheinzle on January 03, 2005 at 07:39:47:
First, the soft plug is behind the flywheel, so taking out the belly pump won’t get you what you are looking for. If the plug is rusted through, with the pressurized system it will eventually blow a larger hole in it. There really aren’t any “gotchas” on taking out the pump.
Post a Followup
Subject:
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
