Re: 504 winter block heating
Posted by Bob on January 03, 2005 at 09:03:22 from (66.163.134.177):
In Reply to: 504 winter block heating posted by Mike (WA) on January 03, 2005 at 08:29:35:
CNH can probably fix you up, here's some info from Phillips-Temro, a block heater brand a local auto supply can probably order.
504 gas or diesel, engine mfd. 1964 or later. Part #3100054, 600 Watt 120 Volt 1-5/8" diameter, Install in place of right center block plug. Point element DOWN.
Costs $18.86 at my local auto parts store.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
