Re: 686 knocking
Posted by captaink on January 03, 2005 at 11:37:11 from (66.115.214.56):
In Reply to: 686 knocking posted by dwp on January 02, 2005 at 19:28:45:
How is your engine oil pressure? If it is good to excellent, a crankshaft bearing is unlikely. If it is lower than normal, I would pull the crankcase pan and start checking bearings. This might still be the easiest place. Another possibility is that the flywheel has come loose from the crankshaft, of course you will need to split it to check this out.
Good luck!
Post a Followup
Subject:
