Re: 504 winter block heating
Posted by Hugh MacKay on January 03, 2005 at 12:41:26 from (64.228.11.86):
In Reply to: 504 winter block heating posted by Mike (WA) on January 03, 2005 at 08:29:35:
Mike: The one Bob speaks of is good, and probably all you need for the temps you speak of. That engine is just 2/3 of the 282 used in 560 and 656. I used circulating tank type on my 656, 560 and a Deere I had. You need only plug the tank type in, couple hours before needing tractor. I was also dealing with much colder temps. Just another suggestion. You just plumb the tank type between block drain and one of the ports on the head. On the 282 those were both on injectors and pump side.
Post a Followup
Subject:
