Re: Super H wont start, electral prob.
Posted by Janicholson on March 10, 2009 at 15:57:05 from (64.83.225.108):
In Reply to: Super H wont start, electral prob. posted by jonnny2006 on March 10, 2009 at 15:43:04:
My first impression is a bad connection in the circuit supplying the ignition switch and possibly the connection at the load side of the amp mmeter. The amp meter showing discharge might be from a short that caused the problem, or it could mean there is a bad wire going to the coil. I would remove the wire from the coil (ign sw side)and see if it has the same draw. if not it could be a shorted coil. This would burn up the points,, and cause other issues with wiring. If the 10 amp load is not there, I would not hook up a hot wire until I found the short to ground or bad coil. Let us know what happens. JimN
