TDC set, but still won't start.
Posted by Tanner Clark on January 04, 2005 at 04:17:32 from (206.239.4.3):
Ok wife and I set the timing last night and got the no:1 on TDC. The pointer was just between the double notches on the pulley. I was able to see the piston real easy, and it had a lot of junk on the top of it. But anyway, The rotor was pointing at like 6 o'clock instead of 2 o'clock, so I pulled it off and turned the shaft on the dist. so that it was sitting at 2 o'clock. I then wired it up, checked everything, put the battery in, and hit the starter. Nothing happened. So I am back to where I was. The only things I have not really checked out is the voltage regulator or the 12 volt generator. Could these be a problem? Frustrated yet again.
Post a Followup
Subject:
